Why does our hot water stink?
    • #40275
      kdewall
      Senior Moderator
        Weird issue, but when we use our hot water only it stinks. Cold is fine. We tried draining the water heater but that hasn’t helped. Any ideas?
      • #40276
          Try changing the anode rod (assuming you have one).
        • #40278
            If your water starts to take on a sulfur or rotten egg smell, it’s likely the anode rod, as Bill stated. I would check that first. If that still looks good then I’d sanitize the water heater.
          • #40309
            kdewall
            Senior Moderator
              Dumb follow up question, what do you clean your water heater with?
            • #40311
                Not a dumb question at all! Its actually one many people can’t agree on.  In my experience, and after reading several owner’s manuals for Suburban and Atwood water heaters, it’s recommended to sanitize with either bleach or vinegar. Check your water heater owner’s manual to see what it suggests.
