Does hooking up to city water fill up my freshwater tank?
    • #41532
      kyle.lange
        Does hooking up to city water fill up my freshwater tank? Mine seems to be…
      • #41555
          No, when using city water it should bypass the freshwater tank.
        • #41582
            Depending on the RV, you have either two separate inlets, one for city water and one to fill your freshwater tank OR one inlet with a valve that you turn for city water or fill.
            So, first, make sure you are hooked up to the city inlet or you correctly have the valve set to city water. If that’s correct, then you likely have a backflow check valve stuck open, allowing water to flow back into your freshwater tank.
            Here’s a diagram to help illustrate my point:
            page-rv-plumbing-system-diagram
