Condensation between window panes
    • #52815
      jeremy.johnson
        I have condensation between the panes on one of my dual pane windows. On a motorhome. Can I fix it or should it be replaced? WHo would you call if it needs to be replaced?
      • #52816
          Typically what that means is the seal between the two panes has failed. You’ll most likely just want to get it replaced. You could potentially fix it, but it is labor-intensive and may not last. It also voids any warranty and may reduce the window’s insulating value.
          As for where, you can order replacements from RV window companies like Lippert, Peninsula Glass (RVWindows.com), or your RV manufacturer. Installation can be DIY if you’re handy or done professionally.
        • #52822
          Pete Sell
            We just went to our RV dealer for a replacement window.
