How can I increase water pressure in my RV shower?
    • #39601
      Chris
        What’s the best way to increase the water pressure coming from my RV shower head? I feel like the water barely comes out.
      • #39602
          Is it just the shower that has low-pressure issues? Are you using city water or your onboard water supply? Is it both hot and cold water?
          A little more info will help us pinpoint the issue.
        • #39603
          Chris
            We only use city water so I havent tried with my water pump. And it only seems to be the shower with both hot and cold water.
          • #39604
            Georgia McBroom
              I switched out my shower head with an Oxygenics and immediately noticed a huge improvement in water pressure. I got mine from Menards, but you can find them on Amazon or at any home improvement store.
            • #39605
                I’d first check for any build-up or gunk in the shower head. Pull it and see how the water flows without it. Could also be a flow restrictor. Pry it out if possible. And I second the vote for an Oxygenics shower head. They work wonders. I use them at home, too.
