AC unit leaking after running for a while
    • #40879
      tim.sell
        Another leaking issue… I tried googling it but google is about worthless these days. My AC runs fine, blows cold, but after running for a while it starts to drip water. Any ideas why and how to fix?
      • #40884
          It’s most likely a clogged drain pan. Pop the cover off your AC unit and clean it out. Dirt and debris make their way into the pan and clog the holes, which then leads to the water draining into the RV.
        • #40885
            Exactly what @IA_Camper said. You’ll need to get on your roof, remove the AC cover and check the drain pan. If you’re not comfortable doing that, then have a service tech do it. It wouldn’t hurt to service and clean your AC every year to prevent things like this.
