Shower head has very low pressure
    • #42363
      kristi.connely
        One of our shower heads has very low water pressure coming out, which is odd because the other one works completely fine. We have the water set to 40 psi. Any way to increase the pressure to that head?? Thanks!
      • #42364
          If your experiencing low flow at just one showerhead I would unscrew the sprayer head and see if the flow is good out of the hose.  There’s probably just build-up/sentiment in the shower head.
        • #42365
          Georgia McBroom
            What Tory said. I’d also consider upgrading to an Oxygenics shower head if you want even more pressure. The difference was night and day when I replaced my stock shower head.
          • #42366
              I’d also bump that PSI up unless you’re comfortable with it at its current setting. 45-50 might make a noticeable difference. Mines at 60 and I’ve never had any issues.
