How do I winterize my washer/dryer combo?
    • #42147
      craig.berde
        As some of you know, I added a Splendide washer/dryer combo to my RV. I got a good deal on a 2100 XC. That said, it didn’t come with a manual. Do I need to winterize it? I assume so since there are water lines running to it and water is pumped through it. If so, does anybody with this model know how to do it? I plan to winterize the entire RV this weekend.
      • #42148
          Yep, you will want to properly winterize it. Since you haven’t already pumped antifreeze into your system, you can follow these instructions (taken from the SPlendide 2100XC owner’s manual).
          If you are currently pumping antifreeze through your fresh water system:
          1. With machine power OFF, turn WASH TEMP knob to ‘HOT’.
          2. Advance Cycle Selector to position ‘3’.
          3. Press ON/OFF button, then press START. Let machine fill until the drum turns (could take up to 1 to 2 minutes).
          4. Press ON/OFF button to turn power OFF.
          5. Advance Cycle Selector to ‘Spin’.
          6. Press ON/OFF button, then press START.
          7. After letting antifreeze drain completely from drum, press the ON/OFF button to turn power OFF.
          Here’s a link to the Splendide 2100XC quick start guide for more info. Might be a good idea to print it off and keep it in your RV. https://www.splendide.com/downloads/QR-RV_2100XC_QuickOp_Winterize.pdf
        • #42149
          craig.berde
            Perfect! Thank you very much for finding that!
