Can I travel with a full water tank?
    • #42151
      glenn.dalbey
        We are headed to a boondocking spot for the first time with no water available. Is it OK to fill my freshwater tanks before leaving? Will the added weight do any damage?
      • #42152
          Absolutely. I have always filled it up before leaving. I stock the fridge, stock the RV with all the supplies we need, and fill the freshwater tank full. Never had an issue.
        • #42153
          Pete Sell
            I always fill with water. The added weight might slightly lessen your gas mileage, but its worth it if you dont have water where you’re going. I always fill mine full to prevent the water from heavily swishing to one side when turning. I dont know for sure if that could cause an issue with swaying or not, but I dont want to put it to the test lol
          • #42154
            kdewall
            Senior Moderator
              Fill’er up! Thats what its there for 🙂
            • #42155
                I always fill it up before leaving, but I would say it depends on the camper. Should all campers be able to handle the weight and not affect driving, sure, but let’s be honest, campers aren’t known for their excellent build quality. If you’re worried about it, I would first check the owner’s manual and even contact the manufacturer to see if they recommend it. You could also do a test run. Fill it up and drive it around your town to see if it affects driving or if there are any issues. We can all share our anecdotal experiences, but each camper is different.
                • #42156
                  glenn.dalbey
                    I figured I would be fine and I was just overthinking it, but doing a test run sounds like a great idea. Thanks
